This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
If the boiler only has a 3c cable to it, it will be a basic boiler which requires a switched live, neutral and earth, not a permanent live. (unless it is intended to run 24/7 and only control is from its own internal thermostat).
A bit of a confusing situation for many, basically a boiler with a 3 core flex (L, N & E) is an appliance that runs as soon as powered (other than any internal system) so when used as a component in a bigger system the 3 core flex becomes SL, N & E. Strictly speaking it should be 'Enable, N & E' as the boiler is likely to have internal safety devices.
In exactly the same way as a light intended to be on permanently Vs switched, IE L Vs SL.
Yep I saw that and forgot to mention it, I wondered if it has caused some internal contact and hence the Tripping
Hi Both
I have a new relay to replace , just need to get the wiring configuration right
Much appreciated Tim
understood that's how it is operating
I meant before you posted it on here
Hi yes
But it kept tripping, problem was when i first visited the job it had the relay had been disconnected due to it tripping the house CU so I was unsure how the relay had been initially connected
So i connected up the house side of the circuit directly without using the relay so they had heating and hot water
I isolated the UFH as this was not critical
Thanks Tim
