ThanksThats the trouble!
I think you will have to do a continuity test on each to see exactly where they go and what they do. Dont think there is an easy fix - lesson learned (or perhaps not as it was the customer who disconnected).
Just dont assume that the blue conductors in a 3core flex are always neutral!
I have connected the wire from the pump L/N/E to the wire from the boiler L/N/E
and the heating in the house works fine
And I have also connected the switched live N & E from the UFH wiring center to the boiler and the UFH in the office runs fine
its trying to connect them both to the boiler via the relay that causes the tripping
Thanks Tim
