Discuss 80w led e40 corn lamps in the UK Electrical Forum area at ElectriciansForums.net
If using these to replace a 250w hit in a low bay light fitting would you just simply snip the Line and neutral from the ballast leave in the lamp holder and connect these direct to the supply ?
Reason I ask is what amps would these be pulling and Would the exsisting cable from the holders ok for these lamps.(I know this will differ from different brands)
I've worked it out at less than 1a
just as a heads up, these corn lamps give out no where near the intensity of light than the 250w metal halide lamps you are replacing, regardless of whatever output they may claim, I've tried a couple of different brands in the past and they just don't cut it! if its a larger project maybe try one first
More length of life is what client is after ,so when a fitting packs in just converting to these ,tbh the ones I've seen are pretty good for lighting levels
You can actually keep the ballast in as long as there isn't an ignitor fitted. Better to remove it though so you don't have to worry about it failing.
Just make sure the centre of the lampholder is the Live and the "screw" is neutral, the lamp holder wires are not always wired with brown and blue.....
Reply to 80w led e40 corn lamps in the UK Electrical Forum area at ElectriciansForums.net
Driven by the recent colossal hikes in the cost of electricity I hit upon the wizard wheeze of replacing some of the existing LED bulbs in our own...
I just rewired my kitchen CFL T8 fixture with direct wire - double ended Sylvania A/B type LED tubes, no more ballast. One single 120V 15A line...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
  • Locked
5K
Greetings, First post here. Would be most grateful for any expertise available on this issue. I am trying to convert 2L fixtures to LEDs. They...
