- Dec 18, 2011
- 5,379
- 6,731
- 405,788
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
I have been asked to price for a supply to an outdoor swimming pool (domestic).
The electric supply will be for a air source heat pump and the pool pump. (see pics)
The pool is above the ground rather than buried in it (so figure 702.2 applies with regards zones). It has metal sides and metal bars going into the ground to support the sides (see pic). It also has a metal rim going around the top of the sides.
The property is TT. Ze = 37ohms
My questions are:
1. Do the metal bars supporting the pool frame need bonding? I haven't tested them yet but lets assume they test as extraneous as they are sunk into the ground. They would not be simultaneously accessible with any exposed conductive parts, however I think 702.415.2 says they need to be connected to the CPC of exposed conductive parts in any of the zones.
2. Would the metal sides and rim need bonding? They would not test as extraneous so i cant see why they would.
3. Would I need any rotary switches for isolation? There will be a IPx5 consumer unit in zone 2 for the heat pump and pool pump. This will have 30mA RCD so there will be local DP isolation already but not for each item. I would think a separate rotary switch for both the heat pump and pool pump would be a good idea.
4. Do the heat pump and pool pump need to be outside of zone 1? Also, does the switch gear (i.e CU) need to be outside of zone 1. The switchgear will all be IPx4 or IPx5. 702.53 says no to switchgear in zone 1 but 702.512.2 says electrical equipment (i.e the pumps) have to be IPx4 inside zone 1. I'm guessing the pumps can be zone 1 and the CU needs to be outside.
pool
pool pump
heat pump
inside heat pump
My questions are:
pool
pool pump
heat pump
inside heat pump
