A
ample current
In a flat to day doing a PIR. There is a fan heater fixed to the wall towards the ceiling. it wired from a SFCU also in the bathroom. This was installed from when the block of flats was built (1987). How does this sit with the EICR form particularly item 6.6? The flat has never been modified in anyway and still has the rewireable fuses can some tell me the BS number of the main switch in one of these please. One further question how do you do the live tests on and economy 7 circuits? (storage heaters) Thanks in advance
We had an old bar heater in our bathroom until it was kncherd. So. No problem.
Rewireable main fuse , can only guess 3036
you could do ze and add r1 and r2
If this was installed in 1987 then as long as it complies to the 15th edition then only code 3's should be noted for non compliance to BGB.
Thanks for your quick reply but was not referring to the actual fuses but the main on/off double pole switch in the distribution unit that isolates all the fuses
if it's like the wylex CU with 3036's the main switch is BS5419, i think.ans as murdoch says regarding the heater and SFCU.
the SFCU was outside zone 1 but the heater isn't, but you are not able reach it from inside the shower
give it as code C3 if it makes you feel better.
So the heater's over the bath/shower? Think you may mean that the SFCU is outside zone 2, but the heater is IN zone 2?
Both need to be outside zones altogether.
