This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Scotford14
Evening everyone. Im working on a large house at the moment and need some direction with the heating system. As far as wiring goes I can handle basic systems but this is one of the larger ones I have worked on. Two boilers are warming a header tank. From the header there are three separate underfloor heating zones, a towel rail zone and two DHW cylinders. I have drawn up a wiring diagram to start with the towel rails plus the DHW cylinders. I would like to know if I am on the right tracks. The UFH panel is a heatmiser UH1. Sorry for the image, I didn't have many colours to draw with
https://onedrive.live.com/redir?resid=d566568f112733ea!2913&authkey=!ADbxB9FG3UbFvIA&ithint=album,
That is a terrible diagram to try to follow, but you appear to have 3 stats in parallel operating 2 valves in parallel for the 2 seperate hot water cylinders.
That's going to end in some very very hot water!
I can't follow the drawing on my iPad. But you should have a header limit thermostat and a double pole relay with the cascaded boilers.
