Q
quickquestion
Does an adapter such as the link below when plugged into an ungrounded 3 prong outlet act the same way as if the outlet was replaced with a GFCI outlet in terms of shock protection? Having a difficult time figuring this out.
Someone had asked in the questions if the product works if there is no ground and one of the responses was...
"That would be a no. It checks to see if there is a fault to ground.
That is something that would more than likely need correcting for several reasons."
Just wanted to make sure that the safety improvements GFCI provides works regardless of ground or if that was only the case if the gfci outlet was hardwired into the wall.
