Hi Guys,
Got my ACA (Approved test) soon and been reading up a lot about what is involved. One thing not too hot on is the motor circuit as I don't work with motors much.
Wondering if anyone can give me any pointers on what I might need to test for the motor circuit- presume for IR, isolate motor and control circuit then test from the supply side and then also test back from Load side also?
Also for the other IR tests, will I have to test between L and N? (at present on an EICR I would link L to N and test between them to E). If this is the case, I would need to remove lamps or any other Loads on the circuits (perhaps ballasts?)
Thanks in advance,
Thanks in advance,
