Discuss Accessory screw covers in the UK Electrical Forum area at ElectriciansForums.net
mhar
Anybody got any tips on how to remove the little plastic inserts that the likes of Click and BG supply to cover the screw heads on the front of their switches / sockets etc? I often use a bradawl but this always damages them and is fairly obvious when they are replaced.
BG normally supply double the amount required so it is easy (albeit a bit of a pain) to collect spares, however Click only supply the exact number required. Is it possible to buy these anywhere?
1st attempts - insulation tape
2nd - Stanley blade carefully
3rd attempt - whatever because it’s not going back in looking nice!
The likes of Denmans Designa range give you 3 in the package which is useful as I’ve had the Hamilton verve (my favourite) only give 1 in the packet which isn’t impressive!
And if you're really stuck a 3/4" screw [or other length lying round in the toolbox] a couple of turns into the centre of the cap followed by pliers on the screw.:)
You can buy packs of these little covers on amazon and at screwfix.
Reply to Accessory screw covers in the UK Electrical Forum area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
What's the most badly designed accessory you've had to install? I present my nomination, the ML Accessories/Knightsbridge RWL5 wall-mounted LED...
Interesting situation has come up. I have a client who rents out portable toilets - higher end ones with proper flushing toilets/urinals that are...
Had to do a CU change in this lovely heat, so naturally it was a bit of a bugger... Replacing a Wylex skeleton board with Type 2 breakers for a...
Hi Happy new year to you all. Ive just had a sort out of my stores. Please see below a list of electrical items for sale. Will sell individually...
