M
martom
I need to wire 2 sockets in loft and 1 lamp. Loft is not converted and used as a storage only, but combi boiler is been fitted there. There will be usage under 10amp. Does it sounds right to run those 2 sockets radial on 2.5 mm t&e protected by 16A MCB? How about taking power for 1 lamp from this radial? Thanks Tom
First thing, as you are installing a new circuit you either need to inform LABC that you are carrying out this work, or are you already a member of a scheme which you can do this through?
Then you need to ensure your earthing & bonding is satisfactory.
Once you have done all that you can then do your cable calcs which should then give you the correct size cable for the job you are doing.
Finally as there are sockets involved it is highly likely they will need to be RCD/RCBO protected.
Sounds ok but you've not stated installation methods, insulation etc. But if the loft is not converted why do they want sockets up there? And I assume by lamp you mean a light fitting? So FCU with a 3A fuse.
Very basic question if you're an electrician or an electrician in training?
- - - Updated - - -
Damn! No one else had replied until I hit enter!
Thanks for answer. Its a very basic question I know. I am bit confused only because i studied electrical engineering abroad and now i am finishing UK training. Different wiring regulations. I calculated of course this radial, i am joining part P now. This is part of my assessment. Thanks and sorry for a stupid question.....
For your assessment this is a reasonable task as it emcompasses a new circuit, cable routing, load, distance, volt drop, fusing down, notification, EIC.......
You'll get the most out of the forum if you outline the "issue" and an idea of how you will approach it so posters can see how you plan to approach it.
Have fun.
Thanks. I have a lots of fun already. Most of my questions has been answered in the past - so I do read the forum and my green book very often, but sometimes I will ask you for help. Just try to imagine that in my country they never heard about a multi function meters- all checks and inspection you do over there is continuity check.....
Hi
Cannot give specific installation advice, This is something that a qualified electrician should know. Best advice is get electrician to do the work
Of course the installation method is included in the calculation. Thanks for advice;) but i don't think is the right way to get a qualified spark to prepare my assessment ;)
martom,
martom,
