Discuss Advice on routing my romex. in the UK Electrical Forum area at ElectriciansForums.net
nilknarf
I'm going to run a 6/3 cable from my panel into my garage for an evse. My panel is in a utility room next to the garage. I need to cross the ceiling of the utility room, which is just below a stairwell landing. The first photo illustrates that I need to run from point A (at the panel) to point B (garage wall). My problem is I don't see an easy way to get from the panel to the joist area where the other lines are running. Seems to be nowhere easy to drill. Could anyone advise as to the best way to route this and still likely meet code? I'd rather avoid running the line along the bottom of the four adjacent joists using conduit, but that's about all I can come up with. Thanks in advance for any advice!
Frank
Frank
First off that’s ugly but it looks like you don’t have much choice but to drill through the floor joists. You can buy wood bits up to 12 inches long, or buy you a bright angle drill. You could take some wire ties and make that existing installation look a little better.
So I'm guessing you mean something like the arrow shown in this photo? How would I avoid hitting that mass of wires? Maybe wedge some kind of plate in there in front of them?
Reply to Advice on routing my romex. in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
DIYer here. I'd like to install an electric car wall charger myself. It calls for 6/2 romex which I have. Unfortunately my panel is in my...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
I would like to ask advice on a breaker size. Back in 2001 I turned my garage into a woodworking shop with several 240v machines. To power them I...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
