dingodeano
Went to look at a job on Friday. To put 2x60w son/efittings on a timer. I am sure that most timers are incompatible with discharge lighting can anyone reccomend a brand ?
Thx
No. I read product spec on time guard fst17 7 day programmer and it says not to be used with discharge lighting. I am assuming the control gear in fitting is not good for timer contacts. So I was wondering if anyone knew of a suitable / tried and tested timer for use with SON fittings?
use the timer to energise a relay/contactor. then feed the SONs of B****es through that
Any, via a contactor.
i have used a standard timer(not a digital clock one) on four 70w sons and it has been working fine for the last 3 years
For two fittings that was my initial thought line hughesy, 'till the programmer came into play. By the way, not heard of a 60w son-e, am I missing something ?
he must mean 70w, just wondering what the whole job is now to see why it needs a programmer , in that case a contactor is the way forward as you said earlier.
Did job. Used mechanical timer. Works a treat. The programmer I intended to use was to offer greater flexibility over the lights - (random on off for when on holiday ect) but this was all not required just on at 4pm off at 9pm
thanks for the advice. Btw the 60w are in fact 70w
