I
iamelectric
been asked to change over 2 consumer units in a house one at the top is for main house one at bottom is for extension ,problem is as you can see in the picture the main gas pipe runs right across the supply arrangment the meter is at the bottom left of the pic , pipe is about 20mm from cutout , should be at least 150mm , the guys not willing to pay for the pipe to be re-routed and i dont think the gas board will do it for free although its their mistake, what do you guys think tell him to get it sorted first or he can get someone else to change the consumer units
Well.... if an existing installation, I would get on and change the board for a new one and note the proximity of the pipe on the cert.
The bottom board looks a bit on the large side for a 6way, wouldn't a new 6way plus the new replacement for the top board both take up less room and then you might be able to fit them both above the trunking and then they will also be installed horizontal and not with 1 of them sideways ?
if gritish bass have stuck that pipe there, get the buggers back to shift it.
cheers murdoch, yeah kas was thinking of just putting 1 in but it would mean extending most of the cables , there is also an issue with the shower circuit its wired in 6mm and wired into a 40amp mcb
6mm is fine on a 40A if it's clipped direct and not smothered in itchy-poo.
can you get a non-combustible insulated partition in there? looks tight, but like kas said, you could get a new 6 way board that's a lot smaller than the one in the pic'.
There's been many many threads on here with people extending cables in DB/CU nothing wrong with that, they all tell me nowadays wagos are the way forward quick easy and most of all fast, you'll still have the shower circuit to sort which ever way you choose to proceed.
nmothing wrong with that gas pipe that a lump hammer can't fix.
just install a JB under the trunking for your klippons/wagos I like the idea of the din rail mountable wagos
