C
chrisc 77
I need to install a socket on the other side of the wall to my CU, there are no nearby sockets to spur off so i was wondering is it bad practice to just wire one direct to the CU? Im not 100% sure.
Que the reply's heading your way for this chrisc...
But its fine, aslong as its only 1...the cu counts as a point.
- - - Updated - - -
Unless you put a fuse spur first.....im sure you know the regs for spurs don't you?
But like i just said, spuring off the CU is completley fine
No fine as long as it's rcd protected 2.5mm cable on a 16a mcb all the earthing and bonding is in place and all the relevant paperwork is filled out afterwards.
Cheers, im just out of college and want to avoid any schoolboy errors if at all possible lol.
Yep you can.
A radial would be fine but you can ring it it you like.
I have seen many 1 socket rings.
dont just say spur off the CU ! LOL
the op might bloody take it off the main switch !!
seen it done before
HAHA
On reading this again, and at my rushed response.........im slightly confused...
you're wanting to spur off the CU, and the CU is at the other side of the room? there is literally no sockets to spur off inbetween you're required location and the CU?
So im guessing, you're going to sling trunking around the walls lol? because you're quite clearlly not taking up the floorboards, because then surely they'd be a socket easier to get to than the CU
Spuring off the CU is fine like i said, providing you do it correctly and in accordance with bs7671........but im sure you know all of that?
Lol im not that bad, just wanted to check as wasn't 100%
- - - Updated - - -
seen it done before
HAHA
Haha, true, my bad - appologies.
I just pressumed he'd know the regs on spurs. Massive schoolboy error to presume such a thing on this forum isnt it lol
Yeah i know my regs-ish , the CU is under the stairs and there is a stud wall between the stairs and kitchen, i want the socket on the stud wall and the nearest socket is across the other side of the kitchen.I literally pnly need to drill a hole in the wall and the CU is there so about 900mm of 2.5 t+e.
Yeah the cu is literally on the other side of a stud wall,hence the question
- - - Updated - - -
Ahhh, see's thats better!
Yeah its fine, aslong as you go into the top of the ring main breaker, or put it on its own circuit.
aye, i can see that now but the way you worded it, i interpreted it as that the cu was on one wall and you wanted the socket directly opposite, in the same room / hallway / corridor / walk in cupboard w.e
