Discuss AFCI nuisance tripping? in the DIY Electrical Advice area at ElectriciansForums.net
An electrician I talked to said that AFCI breakers on old (1950s) wiring tend to experience a lot of nuisance tripping. I plan to install several GFCI receptacles. If I use AFCI/GFCI receptacles, are they likely to have the same problem?
Reply to AFCI nuisance tripping? in the DIY Electrical Advice area at ElectriciansForums.net
Our family room is part of an addition built a few years ago. We had an issue with nuisance tripping on an AFCI and the electrician came and...
I am going to be replacing two AFCI breakers after a lightning strike in a house built in 2003. I will be bringing the breakers with me to ensure...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
I recently rewired my laundry room with MC cable, 20 amp circuit. I installed an AFCI/GFCI combo switch. The gas dryer trips it as soon as I plug...
I have a small power washer with a two-wire cord and GFCI plug. My outdoor and garage receptacles are on a "house GFCI" circuit, wired in series...
