Discuss Am I an idiot. in the Australia area at ElectriciansForums.net
S
swordfish
Hi. another new guy here. I have just finished first fix on an old cottage. this included meter position change. Having been assured by Western power that they would not be supplying an earth i duly installed 10mm earth for TT installation to go along with my 25mm tails. On connecting up western power have now told me that this can be Tn-c-s. Am I stuck with having to put a rod down in terrible soil because of my earth CSA. P.S In my absence they have already connected the 10mm earth to their neutral. Any advice appreciated. PPS I indend to let the NIC look at this job for my first assessment.
Swordfish.
Dont see this as a problem. You will need to swap out the 10 for 16mm though.
Then just carry on as PME system and whip out the rod.
Reply to Am I an idiot. in the Australia area at ElectriciansForums.net
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
I have carried out home wiring for 60 years as a competent person, for the last 20 years, I employ a local electrician to check my work and sign...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
