Discuss AM2 help for Monday please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Got my AM2 Monday, just wondered if anyone could give me any advice if they have taken it before or things to be wary of.
Could someone please explain to me using fly earth leads, when to use and when to jot? Might seem simple but my college have basically put me for the AM2 with barely any help from them
Do you have to use fly leads connected to a banjo when using SWA and SY cable. Also when doing the PFC tests do you test each phase to earth and double the highest reading and record that as you ipf and just record the PSCC (phase to neutral??) on the back of the test sheet
If the sheath or screen is being used as protective conductor then yes, you need to banjo and fly lead to the earth terminals.
Be careful with your terminology. Measure PEFC (L-E) and PSSC (L-N), the highest of the two values becomes the PFC. Record this value if only Single Phase is present. Double it and then record value if Three Phase is present.
Another question, on my test results I have 2 circuits that are 3 phase do I put e.g motor circuit L1 then all the results for that phase then underneath motor circuit L2 then all the results etc or do I put motor circuit and take the highest reading off all of the results I get for each phases and use that?
Hello Anthony,
Just interested in how you got on in the AM2 test?
Phase to phase is the worst case on a 3 phase supply this should be measured then doubled and recorded
Reply to AM2 help for Monday please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the...
I have my AM2 coming up next week but something is puzzling me and I’m hoping someone can help me out. So there is some SY cable coming out of...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
Hi, I’m just looking for some advice/ someone to point me in the right direction please. Basically I worked as an electrician for 5ish years...
