Guest viewing limit reached
Hi does anyone have any good advice for the AM2, I have it booked for November at ERR in Birmingham cheers
As long as you can read a wiring diagram you’ll be fine with the practical. The heating system scares a lot of people but it’s easy.
Make sure to flick all the switches when doing insulation resistance on the lights (and disconnect anything vulnerable to test).
They’ll ask a few questions. I know a lot of lads have been asked how to calculate R1+R2 on a ring. r1+r2/4.
Almost everything you need for the testing is in your GN3.
Good luck!
Upvote 0
I would recommend you do the refresher days, they helped a lot, make sure you do everything they tell you in the folder they give you. I took mine 3 months ago now in Birmingham and been told it’s the best centre to go to. They examiners are really nice and calm, the guy I had even helped me out if I looked stuck (like gestures and asking if I’m really sure about what I was doing, hinting I was wrong).
The practical is easy, just have to read the diagrams they give you and can’t go wrong, The online exam there’s nothing to worry about, the books they give you tell you everything and the questions tell you where to find the answers. Testing I found the hardest but if you go to the refresher days they go into so much detail about how they want it done and I wouldn’t have passed if I didn’t got to that.
Good luck mate hope some of this helped
Upvote 0
Hi mate,
I took mine this year, and there was lots of advice threads on this forums which helped massively.
A good bit of advice I would give which helped me, was have in your head what order you're going to do the install in. I did the bits which I found most difficult first, but I know some people find doing the things they find easiest more helpful, so just find out what works for you mate
Also read the spec!!! sounds simple but many people fail by not following it.
Best of luck mate, and as others have said, the refresher definitely worth doing.
Cheers
Upvote 0
Make sure you read the instructions clearly when doing your practical and testing .
if you haven’t done any testing , make sure you get some practice in , there are a good few videos on you tube that clearly show you.
the theory exam , you should know about 10- 15 questions out of the 30 already , answer them first , that will give you more time to look for the answers for the other questions you don’t know. You will have regs book , osg, and building regs book , it’s just finding them quick enough , but the more you know , the more time you have on others .
Upvote 0
manchester
Business Name
CLAXTON'S ELECTRICS
Am2 help
Electrician Courses : Electrical Quals
Thread Tags
Tags Tags
am2 help
mark claxton,
Zumbify,
Electrical Courses
