There was nothing wrong with the old Wylex wooden CU's with the open backs. So long as you fitted them on non-combustible material. The wood used was seasoned hard wood and is probably far better protection than any plastic CU. At least they won't melt down to a molten blob!!! The fronts on most of those older Wylex wooden CU's was bakelite, so they weren't going to burn too easy!!
The wooden CU in the OP's photo's is a different matter altogether. That is, ... made of cheap soft wood, and were often home made back in the 30s and 40s. Electricians were multi trade in those days, that often took in carpentry as a major component of an electricians work, singles were often run in a wooden grooved capping that ran around and in-between rooms, Some of the joints and mitres in that wood capping, were better than some of today's carpenters could achieve...lol!!!
