It’s standard 25x16 Trunking for CCTV.
Should be straightforward
Tool for marking the angles ( forget the name) and a large hacksaw and a file
Maybe adjust if the walls are off
25*16 is very easy to work with
Nothing wrong with the sticky stuff it's the way you use it, used many kilometres of the stuff with no problemJust don't get the sticky stuff
Fix the regular stuff
I’ve never seen one before. They look interesting.If you want clean and accurate cuts then my tool of choice would be a pull saw
Bahco PC-9-9/17-PS Pc-9-9/17-Ps Profcut Double Sided Pull Saw 240Mm (9.1/2In) 8.5 & 17 Tpi
Length 240mm (9 1/2 in)Teeth 8.5 and 17 tpi....www.powertoolsdirect.com
They are very good for precise cuts, the one I linked to is my preferred style as it is more versatile but if you do a search on Japanese pull saws they are available in different stylesI’ve never seen one before. They look interesting.
But I at least want it to look good. I will be filling in and around with caulk.
I always go around the edges with caulk. Because I’ve used a large hacksaw in the past it’s not the smoothest of cuts. Something like the Japanese Saw may change that. Plus its getting painted to match the room. A bit of caulk on the mitre joints isn’t so bad.Looking good and filling any 'gaps' with caulk (which can look s......te after a few weeks/months) doesn't bode well for for the best of looks!
I would always use the preformed angles and T's, box adaptors etc. for the most professional job but you've already dismissed that idea in previous threads.
I've tried mitre saws and whilst give a good 'edge' buildings are never 'square' so makes it very difficult to cut it perfectly!
It’s for CCTV.Keeping the customer happy is key, and it's not as if its a deviation from the regs (unless using singles and they show through gaps in the joints)! which there wont be if filled and painted.
