Staying in place from the start is great, but usually I would pop in a couple of screws to make sure it stays that way!Nothing wrong with the sticky stuff it's the way you use it, used many kilometres of the stuff with no problem
That is the big down-side.Also gets stuck in the wrong position if you're not careful
Upside is it only needs 2-3 screws per length to stop it migrating over time as the glue slips a little.
Need a line drawn before affixing otherwise imo
I always fix it with some screwsStaying in place from the start is great, but usually I would pop in a couple of screws to make sure it stays that way!
It is not that inconvenient to bang a few screws in and probably a lot quicker to fix than the non sticky trunking also on a horizontal fix you don't get the brick dust trail down the wall that has to be cleaned upI can't be bothered with it seeiy as how you have to add a few screws to it
So it only sticks in the wrong position if you are not careful are you admitting to not being careful?Also gets stuck in the wrong position if you're not careful
Not too bad if it's running along a corner or top of wall
Or just use a 2ft or 4ft spirit level as a straight edge to fix it againstSet the laser level on the floor and line it in seconds.
