problem with the manufactrured joints is thety are bigger than the trunnking itself so you end up with a gap along the trunking.
Staying in place from the start is great, but usually I would pop in a couple of screws to make sure it stays that way!
I always fix it with some screws
I can't be bothered with it seeiy as how you have to add a few screws to it
It is not that inconvenient to bang a few screws in and probably a lot quicker to fix than the non sticky trunking also on a horizontal fix you don't get the brick dust trail down the wall that has to be cleaned up
Also gets stuck in the wrong position if you're not careful
So it only sticks in the wrong position if you are not careful are you admitting to not being careful?
Not too bad if it's running along a corner or top of wall
Need a line drawn before affixing otherwise imo
Set the laser level on the floor and line it in seconds.
Or just use a 2ft or 4ft spirit level as a straight edge to fix it against
RDB85
Trainee
Liverpool
Trainee Electrician
Angles on PVC Trunking
Electrical Tools and Products
RDB85,
UNG,
