Hi
By wiring diagram I can't see slot for UFH wiring centert to boiler for control. Please advice from photos
The Heatmiser boiler control is the zero volt contacts labelled 'C" and 'NO' on the 'Boiler' terminal block.
You would need a connection from the incoming Live of the boiler to 'C' and then a separate connection from 'NO' back to the boiler switched live Lr.
If a flex is used, both conductors can be live, so you would sleeve a blue wire with brown!
Greenstar boilers (if that's what you have) seem to have have different mains terminal arrangements depending on the model.
If you're not clear this might help -
View: https://youtu.be/iJ3nPK9ZSJs?feature=shared
Warrington
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
Wiring center to boiler
DIY Electrical Advice
Thread Tags
Tags Tags
wiring
Proo1988,
Avo Mk8,
