To bunny hop, the basic version, is to travel along with pedals level. The front wheel is easy - that's down to the arms pulling up on the handle bars, but the back wheel is tougher...
So as I said, travel along with the pedals level. Point your toes downward so that the pedals are tilted. Crouch low and then, keeping your feet on the pedals, lift up. The lifting motion of the legs / feet with the pedals tilted will force the rear wheel off the ground.
It takes some practice and you'll get there.
Practise with just the rear wheel for a bit, to get used to how it works. In a way, it's a bit like a horse or donkey doing a "Buck".
I don't know if I explained it very well, but I learnt years ago from an article in Mountain Biking UK*
Look on the net - there'll be good guides there.
Oh, and to get higher, you need to crouch lower, so a low saddle helps too.
* Other Mountain biking magazines are available
