Discuss Any one flexishield cable befour in the UK Electrical Forum area at ElectriciansForums.net
i think that flex shield is still to be recognised by bs7671 as a cable type that doesnt need rcd protection , like pyro & swa , thus has limited use.
its biggest obstacle is its limited to 170A fault current , as stated in the advert.
If its BS8436 then it is recognised by BS7671 - see 522.6.5 (that was the BRB - green book is in the van!)
Obviously as its limited to 170A can only be used on circuits up to B rated 32A MCBs.
I did a whole house in this because I couldn't run cables through floor joists. Old (1700s) house!
unfortunately alot of rcbos these days are in the type C flavour , even for domestic Cu's depending on the brand.
an unwarey installer may get caught out by its limitations so its use should be cautious if not using rcd protection , just a thought.
But this negates the need for RCBOs, relying on the over current functionality of MCBs to disconnect a fault, type B MCBs are widely available.
Reply to Any one flexishield cable befour in the UK Electrical Forum area at ElectriciansForums.net
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Is blue neutral or earth when there is a black cable (which is the old neutral) - old system? Other one is red, no green / yellow
Seen a couple of videos with Doncaster cables now producuing a T&E with the CPC already sleeved so no need to fit our own. I also read somewhere...
