OP
Toneyz
This is not a consumer unit mcb's etc wylex identical with another name for another country eg like we used to have Marathon and others had Snickers. Just the name and printing different.
Discuss Anyone go the BBB to hand - reg regarding mix and match in the UK Electrical Forum area at ElectriciansForums.net
What have I missed this time??
thanks.i'll make a note of that. .If I have learned one thing from this forum there seems to be a lot of notes on Certs going on.
Are they nessary under the regs..I dont think so unless the cable is buried. Or is munufactors instruction Although I always do fit myself.funny that. just quoted a job to fit a new shower. 1960'shager DB, no RCD, and the ptatt who fitted the existing shower ( 9.5kW wired in 10.0mm ) fitted a 50A Volex MCB on it. this was under 3 years ago, so apart from mixing devices, he'd completely ignored the fact that he should have fitted a RCBO.
Yes they are necessary.Are they nessary under the regs..I dont think so unless the cable is buried. Or is munufactors instruction Although I always do fit myself.
question is , though, if replacing a shower like for like, no alterations to wiring, is it mandatory to fit RCD, xcepting following MIs?Yes they are necessary.
All circuits of locations containing baths or showers require RCD protection.
Must have misunderstood something somewhere.question is , though, if replacing a shower like for like, no alterations to wiring, is it mandatory to fit RCD, xcepting following MIs?
Reply to Anyone go the BBB to hand - reg regarding mix and match in the UK Electrical Forum area at ElectriciansForums.net
