S
se1landlord
Looks like a Deta make.
Faulty switch, or just someone not tightened up the terminal screws? I see heat damage on the load L
yeAH LOOKS like the bottom left terminal is burned out
you can probably pick up a near identical switch from any decent wholesalers
Surprised to not see any branding on the back of it, even the absolute tripe that is sold in Home Bargains has branding on the back of it
Deta. Have you tried prising off the cover plate to see if the make is marked beneath it?
Is the cheap or expensive?
It’s quite expensive, yes, probably about a tenner above market average, especially given the fact that it’s deta.
The same switch is on eBay at 14.95 but I just put the link up before to the first one I found on a Google search … not checking price obviously 🙄
£26 is blooming expensive i would never pay £26 for a cooker switch
I don’t think it matters what the price is, the OP has disappeared.
Yes, Deta isn’t the greatest, but they do put a brown/blue ring around the terminals which helps if it’s not good light…..
Ie, under a kitchen wall unit
se1landlord,
littlespark,
