Is it not possible that RCBOs might hold? If current between respective live & neutral is in some way equal or less than tripping level it might be possible for it to hold.
An interesting probability and if both RCBO's are working then absolutely possible in theory but the resistances of the respective "lives" and "neutrals" would have to be so well matched to achieve this apportioned of current ..... practicable possible I doubt very much but Im sure someone on here can offer the calcs to support/deny this!
Lol, on paper maybe it's possible but in practice the chances of the current flowing on both legs of the live and both legs of the neutral being within 30mA of each other are slim to zero. Also bear in mind this point of almost absolute equilibrium would need to occur exactly where a socket is installed......I think we can call this myth busted ;)
If the ring was perfect they would hold. Anyone ever seen a ring with 0 Ώ difference at every point to source? I don’t think so. The slightest difference between either leg and you have out of balance currents, just what the RCBO is designed for. One will be slightly faster than the other, again ever done a ramp test and found two be absolutely identical?
Like rock I’m skeptical about this set up
If you go in to MV (11KV) then you will come across a ring with two feeders, but these are “open ring”. In other words there is an open point that can be moved using Tee switches. Designed so that a section of cable can be isolated using the various Tee switches. Each leg is designed to carry the full load. OK they are a bit specialized. 630A @ 11KV is the normal rating for the section switches.
Have you confirmed you have cpc end to end continuity because i have seen this poor practice done before as a quick bodge it and disappear job. Reason behind it normally is because the zs max tolerance of a normal 32a mcb is exceeded by the loop values taken on the broken ring. Rather than locate and rectify the break the easy way out is do that!
What has CPC continuity got to do with balanced load on L N? RCBO’s and RCD’s could give a flying F about the CPC.
I was referring to the op. If you then move the thread onto the subject of imbalance across l-n then the cpc theory becomes irrelevant. You originally asked if this had been seen before and i replied with an explanation. FULL STOP!
I would have thought confirming L&N continuity is more pertinent to the fact. Or has someone changed the laws of physics since I retired?
I agree but how many sparks nowadays actually know what they are testing or the principles of a ring anyways. If they did you wouldn't find what you posted in the picture from the get go.
That’s down to the competence of the individual.
I can’t help it if the domestic side has gone down the pan. There’s no excuse for not knowing the theory of how things work. If you don’t know, leave well alone.
Or go to the DIY section of this forum lol.
If you listen really carefully, I've just heard Kirchhoff turning in his grave.......
Was an empty council house was holding with no load on it. As soon as the fan spur was energised they both tripped.
Looks like you have a bit of searching to find the link then, either that or connect into a single 32A RCBO breaker if everything else tests out as good to go... lol!!
Had this last week - two "rings" stuffed into one 32a and a radial on a 16a except one leg of one ring is in the 16.
Had to break one ring due to a fault under the floor under the underfloor heating :-[ and re-arrange the rest.
2 radials, one ring and one, apparently going nowhere, left disconnected.
Simples
