Discuss Anything you can do I can do better! in the UK Electrical Forum area at ElectriciansForums.net
D00DY_T00DY
No you can't. yes I can!
Another (late) friday game.
Thought it'd be fun to have a p**sing contest:D
Someone says work they've done before reply if you've done it bigger and better.
I can see this being fun as there's someone(tel) that'll go over the top :D
Biggest cable I've worked on is 35mm 3 core armoured
Go!
I've had worse!
Connecting big cables is backbreaking but satisfying but it is the small fiddly stuff that makes people chuck tools about.
400mm 4 core swa is the largest I've worked with. To be fair, my company hired a cable gang to pull that one in, I helped, but the most I could do was lift it and go with the flow. Back breaking. The standard cable on the same site was 240mm 4 core, 100's of metres of that went in. Now self employed I've been demoted to domestic installer :)
Im in the same boat steve . I find it difficult to get anything other than domestic and light commercial being a non vat one man band :(
Standing inside a rotor? You mean stator?
Cleaning dead Starlings from a Salt Water load bank for a Paxman 410 gen set
Reply to Anything you can do I can do better! in the UK Electrical Forum area at ElectriciansForums.net
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
Those week I have mostly been fitting 20 x 10W flood lights on the sloping edge of a converted mill ceiling, nothing is straight, nothing level...
Picked up the keys this morning and had a quick visual… will do the actual testing on Monday… but what I’ve found so far…. (Not necessarily...
