I'm just a trainee but I already started to buy tools, hoping to use them soon.
I keep this file that I update regularly that will eventually contain everything I need as an electrician. If I liked a brand over any other for personal reasons I included it.
LEGALESE:
BS 7671 (IET Wiring Regulations)
Memorandum of Guidance on the Electricity at Work Regulations 1989 (HSR 25)
Approved document P
IET On-Site Guide
Electricians Guide to the Building Regulations
FASHION:
Cofra Eindhoven Water Resistant Work Trousers or Cofra Bricklayer Kneepad Trousers
Kneepads
Cofra new electrical safety boots, merino wool/wool/bamboo socks
normal and thermal gloves, neck warmer
safety glasses, Bolle BLEPSI safety goggles
hi-vis vest
head torch
Casio F-91W watch
Centurion safety helmet (white), bump cap
insulating gloves (IEC 60903 gloves) for live work
disposable filtering face-piece, half-mask respirator
ear defenders, ear plugs
CARRYING TOOLS:
backpack, wheeled toolbag, pocket pack
padded belt, tool pouch, padsaw holder, drill holster
STATIONARY:
A5 writing pad, eraser
BiC 4-Color pen, golf pencils, Sharpie permanent marker
Casio fx-991ES PLUS scientific calculator
KNICK-KNACKS:
cable ties
dust cloth
lube (cutting oil, wd-40 or something)
masking tape
insulating tape (brown, blue, yellow/green)
hand wipes, tissues, contact lenses
TESTING ETC:
voltage indicator to GS38, voltage proving unit
multifunction meter, multimeter
clamp-on ammeter, non-contact voltage detector, socket tester
VERY BASIC:
screwdrivers set, offset screwdriver
C.K lambfoot knife, stanley knife
combination pliers, snipe nose pliers
C.K T3963 cable cutters 160mm and 210mm
cheap cable cutters for screws
pincers
waterpump pliers, adjustable spanners
allen keys
IMPACT, PENETRATION, FRICTION AND STUFF:
needle files 150mm, engineer's files 250mm
bradawl, gimlet
bolster, cold chisel, wood chisel
claw hammer 8oz and 16oz, rubber hammer
square wood log for trunking (substitutes rubber hammer)
junior hacksaw 150mm, hacksaw 300mm
Eclipse hacksaw blades 150/300mm 18/24/32tpi
padsaw, coping saw
MEASUREMENT:
calc sheet (formulae, blades' tpi, etc)
steel rule, tape measure (self-retracting)
combination square
spirit level
POWER TOOLS AND BITS:
18V combi drill 2x5Ah batteries, impact driver
(idealmente: 18/20V, 2x5Ah, high Nm, regulable torque (Nm) and speed (rpm), 13mm or greater chuck and single keyless, 2 gears)
drill bits
Makita ottima marca costosa, DeWalt, Bosch blue
MCB LOCKS/HASPS FOR LOCKOUT:
padlocks: ABUS 64TI/35, ABUS 64TI/30, 64TI/25, 64TI/20 [lock ID format: 4B; significa: 4mm di diametro, lock B]
warning signs large (A5) and small (tag on MCB, about A7): "WARNING - Electrician Working" "Do Not Switch On"
clear sign holder
barriers
FIRST-AID KIT:
tweezers
distilled water, eye wash
antiseptic wipes, antiseptic cream
plasters, dressings and bandages
