The resistors are in the right terminals, it looks like in the first picture the blue/white wire to the second detector is not connected to anything, try connecting it to the white wire that it is twisted to.
Can you post a better picture of the first images terminals, I am finding it hard to see whats connected to what.
Ideally the wires joined by twisting need soldering and insulating too.
Hi guys. Thank you for everyone’s help in trying to resolve this issue, I do appreciate it.
Here are my thoughts, when both PIR’s where installed - either side of a partition wall - I believe that a single cable was used and the wires spilt between the two PIR’s. When reinstalling the two new PIR cases the wires where not long enough, so a different cable was used with different colours. So as you guys have worked out the white/green and white/blue wires aren’t connect at all.
London
Aritech CS350 Open Zone
Security Alarms, Door Entry and CCTV (Public)
Thread Tags
Tags Tags
zone
Traveller19,
Traveller19,
