Hi All,
I have a job to install 6mm supply to a small outbuilding. Ideally i would run SWA all the way from Meter box(im taking it from Henley block) to the outbuilding, but not in this case. Cable will have to go through the kitchen area. So im thinking to have 6mm t&e in trunking, it's only about 4 meters. But my concern is that this cable has 2.50mm earth conductor as opposed to 6mm on swa. Another option is to run 3 singles in the trunking, all 6mm. Is that good practice?
Any help would be great
