Discuss Aube TH232 showing HI in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hello
My Aube TH232 is showing the error message HI which means the actual floor temprature is above 70C
But its not....the floor is at ambient temperature of 24C
Its not the thermometer as I have swapped it for a new one with the same error message
So I presume the sensor has failed? Would I be correct? Even if nothing has changed and the sensor is embedded in the floor somewhere?
The system is approx 18 years old but has worked fine until now
Are there any solutions that don't involve ripping the floor up to put in a new sensor? Could I attach a new sensor and just leave it hanging?
Many thanks in advance for any help
Confused...
I don't suppose they put a back-up sensor in there may be some unterminated wires within the controller.
Your options are to pull the floor up to fit the new sensor, get a controller which doesn't need a sensor or see if a remote sensor (doesn't need to be under the floor) is compatible with your controller.
Thanks all
A replacement sensor is not going to feasible and I'm not wild about digging up the floor
If anyone has any suggestions about a new controller and remote sensor I would be delighted to recieve them
Thanks - I also saw this in the instruction manual
Unfortunately the controller was originally located in a cupboard in the shower room that contails the boiler so that's why I was thinking about a new controller with a remote sensor
Unfortunately there is no remote for the Aube so I need a different make
But thanks for all your help
Reply to Aube TH232 showing HI in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi all, I have a slightly mish-mash heating set up, in that downstairs I have wet underfloor heating with an individual thermostat per room, but...
Hi, I've not really got involved in underfloor heating before, but a customer asked me to replace her OJ Microline manual stat for her bedroom...
Hi all I have an electric underfloor heating system in my bathroom with a Timeguard TPT88 controller: (TPT88 - 24 Hour/7 Day Multi-Programmable...
5K
Hey all, Looked at an elements eStat 761 controller today as during loads of other jobs, customer said not been working for some time since buying...
7K
O
Hi there, So first things first, just bought myself my first house . 1920's build in Wiltshire. Should have the keys to it next week, can't...
9K
