Southern Spark
i have just installed a new kitchen at home that was designed by the kitchen designer in b and q, with my input. having just about finished it i am worried about the tall larder unit that is next to the hob. I know common sense should of prevailed, but i was so caught up in installing the kitchen i just didnt think :(. is there anywayi can over come this problem, i.e a glass splashback up the side of the unit? and do you think there is anypoint in moaning to b and q, afterall they designed it this way?
If it meets the hob manufacturer's clearance recommendations then don't worry about it.
If not then have a word with B&Q, or tile it like Spartykus suggests.
yes you can get glass splash backs made but its not cheap. maybe stainless steel type of thing
A friend of mine, used icing colour concentrate to coulr the grout, when he tiled his bathroom.
(Just attempting to maintain the link between tiling and cakes).
spread the cake mix on the wall before baking. then turn the hob on to cook.
Seem to remember a minimum distance to a side surface for hobs, think its 450mm or something. I know its law on gas hobs and a recomendation on electric. either way its poor service from B&Q not to mention this to you. shows you that computers and there know nothing operators in these big places just want your money and offer no service whatsoever.
I agree that tiling would be the best option unless you want to spend some big bucks on a splash back.
id go stainless,tilling will dis colour quickly and stain and look dirty,im a bit of a cook on the side,you have two types of kitchens,a working one and a show home one,if all you do is heat a tin of soup on it tile it,if not stainless or glass backs are a must.
Thanks for all the replies guys... it is a proper working kitchen that will have a lot of cooking going on, /i dont fancy tiles and a splashback can be bought for about £80... It has really done my head in, i have tried to do a great job on the kitchen and I just didnt think. I will try and blag the splashback from b and q, by saying there designer should of warned me. (though i am still kicking myself for not thinking of it earlier!!!)
Hi Southern SparkYou should have a clearance of 300 mm from edge of hob to any vertical surface. If you have this or more you shouldnt need anything
Southern Spark,
Sanke,
