G
Guest 004
The problem is clearly on how the PFC was measured. Which is not clear on the question, as it says 230/400. So you either go with 230 to give 0.14, or what I am leaning with 400 which is 0.25
Assuming that a pfc can only be measured off a singles supply one at a time them doubled by calculation. I would work it out as 230v divided by 1600a pfc = 0.14 ze
why would you go with 0.25 on 400v ? Is it because it feels better but it wrongThe problem is clearly on how the PFC was measured. Which is not clear on the question, as it says 230/400. So you either go with 230 to give 0.14, or what I am leaning with 400 which is 0.25
^ Just ohms law isn't it
0.287 ohms
The lecturer who showed my group the question said it was likely it was designed to mislead (or a 'trick question')
