Discuss bad ground causes short? in the Auto Electrician Forum area at ElectriciansForums.net
i recently installed a led light kit into my car interior and after turning it on, it worked for about 5 seconds before smoking, so i took it all back out of the car, installed it on a 12v computer power supply and everything worked fine, the only differences between the two setups are, one was grounded near the fusebox to a spot i grounded my multimeter to while testing for voltages at fuses. the other setup, was grounded right to the power supply. is it possible that a bad ground caused it to smoke?
No, a bad (high resistance) ground connection will simply stop it working or make it dim or flicker. What probably happened was that the hot wire of the lighting was in contact with the car body. The resistance was high enough not to blow the fuse, but much too high a current was flowing. When removed from the car, this short was cleared and it worked correctly.
The PC power supply will output a very accurate and consistent 12vDC. A car battery could easily read 13.5v(engine off) or even up to 15v with the engine running.
Was it specifically a 'car LED kit'? i.e. it has a wider input voltage between, say, 11v and 18v?
Yes. Was made for cars, and I guess what was said makes sense because before the lights were actually on and working it was just a red light but I drove for about half an hour with no smoke. Then as soon as I turned on the lights it smoked. Kinda odd
you got cars in Canada????? thought you had dog sleds and snowmobiles. o_Oo_Oo_O
Reply to bad ground causes short? in the Auto Electrician Forum area at ElectriciansForums.net
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
I wired in an auxiliary fan to my Jeep radiator. Details: 1. Fan grounded to body. 2. Power wire for fan goes to standard 4 pin relay (with...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
