L
lockhes
i have been to look at a job to fit an extractor but i cant vent directly outside due to conservetory.
my options are either in line fan and go out gable end which is 4m away from fan or rooftile vent
dont really want to use rooftile as it will mean climbing over roof due to conservatory at side i need to be at.
so my question is how powerfull would inline fan need to be to pullmair 4m so condensation doesnt build in tube
room is aprox
w 2.5m
l 2m
h 2m
done a online calculation thing that comes back at 59ltrs sec
would this be enough to pull through duct
hope i have covered everything lol
A high pressure in line fan would do it but remember to make sure there is enough draw under the door!
You need to make sure its the right type of fan,a centrifugal fan will vent distance much better than an axial fan,the capacity of an axial is for short distances,over any sort of length they are next to useless
What's the relevance of that?
I'm sure that the op if aware of what is notifiable work seeing as he is taking on this kind of work or are you the Part Pee Police?
Who said about part p, as your installing a fan in a domestic property it is a requirement to notify local bc or if you are competent and registered with a governing body sign it off. Nowt to do with part p as it isn't covered under that
The Police,Enforcement and Merthyr Tydfil
Now that's 3 words combined that I would like to see in my lifetime
Even if it wasn't Merthyr,"Part P enforcememt in Wales"
"Are you actually serious a1colly"
Part p covers your cable (the electrical side, sorry stupid phone deleted part of my post) the fan is not covered. Any domestic Ventalation that is not a like for like replacement is notifiable under part F either through bc or notifying body that covers part F,so you add a new one or increase the air flow of a replacement that needs notifying. How many electricians are aware of the dangers of fitting oversized fans in domestic properties!
Oh and I did see one police officer, once, somewhere for a very short time up here lol!
Core drill out through the wall with a 4" core and place the extractor fan on the wall. Take a 4 core cable from the ceiling rose to a fan isolator switch and from the fan isolator switch to the extractor fan. Vent Axia Centra SELV would do the job. It also complies with the building regulations Part F. It runs continuously on a low speed and when the switch for the light is turned on, it boosts the fan
ta cheers for that des iv only fiited to vent them outside so never used in line fan before
You'd better go and re-read section 3.10 of Part F before you go around telling everyone to notify their LABC of fan installations. No need to notify the installation of a non-adjustable, stand-alone extractor, other than for any Part P related nonsense.
if the fan is in-line, in the attic and all switches etc. are outside the bathroom, is it then still notifiable under part pee? also, would RCD protection only be required under 533.6.101? comments, please.
Assuming it ain't on a new circuit, if none of the electrical installation falls within the zones it ain't notifiable under Part P. Dunno what 533.6.101 says my 533 doesn't go that high :-)
Vent axia va100 is a very good in line fan. Whatever you do don't use a selv fan they are rubbish they couldn't even pull back your .................:tounge_smile:
