Silly Sausage
I want the downlights working from low light levels till 11pm and the mood lights from low light levels until morning.
I think it depends on if he means 'and' or 'then only'.
Hmm yes Thats what I thought, so basically the lights will be on and the other lights off, then when the lights that are off are activated the others then which were on go off, so he can never have both circuits on at once? if that is what he wants then you are quite right.When the timer is not energised the feed to the main lights through the n/c contact will be operational. When the timer is energised at 11pm, the n/o contact becomes closed allowing the swithed live to turn on the mood lights and the n/c contact becomes open meaning that the main lights don't turn on when the pir is activated.
Easy
feed to the pir
away from the PIR to the volt free common contact of the time clock
then use the other 2 contacts of the time clock to go to your lighting
obviously don't forget your feed to the timer
Sorry...See post #13![]()
