dannyboy91
Right guys I'm going to dip into your wealth of knowledge having looked through my NIC books I think I'll get better answers.
I did a Condition report on this board in London yesterday. (yes I know what your thinking, looks like a pile of ****). Its an old Metal clad CCU with BS3871 II MCBs and one cartridge fuse 3036, does anyone know from looking what the BS number is for the Main switch. It had nothing written on it, not even a current rating? i know its a long shot but im sure you've all seen them more times than me.?
Also these old MCBs, do i need to upgrade them?. My bosses view was that when we do the EIC (once the remedial work is done) these MCBs, which i cant even find in my on-site guide, don't comply with current regs? as there are sockets for general use, no responsible person, no RCD protection on socket circuits? i wasnt to sure so thought id ask you guys what you do? i could understand when i submit the EIC then all has to be brought up to 17th, but wasn't sure, i get conflicting arguments?
And yes the trunking lid missing, Cables doubled over, holes in board which you can put your fingers in, no grommets etc etc etc was all noted before you ask ;)
cheers guys.
Main switch is probably a BS 5419 and why would you want to change the board? You can't give a C2 for sockets just because you want to force a board change on the client.
If they have outside sockets I'd be recommending RCD IP sockets be fitted, as I have just done.
Cheers....Exactly, i wasnt so sure you had to change it. Yes the holes can be sorted so no one can put there fingers in there, but there are no outside sockets and they have a competent person there anyway (maintenence man). yes its years old and maybe recommending its gets upgrading, but like i said i didn't think the whole thing needs changing, as it complied at the time.
cheers guys.
Is this domestic? those are the mcbs that replace the rewireable ones, rcd protection only required for outside sockets.
are you sure they're BS3871? the old push button ones were, but these flip switch type are generally BS60898. check on the side of one.
exactly what Leeds city council were up to Murdoch in that market...
that old tatty wylex is made entirely of steel and brass and will outlast any flimsy piece of crap you can buy today.
but you often come across a mix of the two..
had it loads of times when some of em are 3871s...
so you have to be mindful when filling out the schedule of tests...
which has just got me thinking.........
if someone made a retro fit plug in rcbo , then these old but solid fuseboards would never need to be ripped out while they have years left in them ???!!!
what an outstanding , time saving , cost reducing , best selling product that could be ?
im on to something here !
:-D
:-D
that really is a good idea, partner
