P
Paul1985
hi hope you guys can help me out little, my work has asked me to change a couple of things on some machines at work. The one machine it a very old hydraulic break press they want me to fit an emergency stop pedal the stop circuit is n/c 415v. where is the best place to order one from or could i make my own using a limit switch and some bar (we have a fabrication workshop) all the ones i have found are 230v and look really small.
The other machine is a roller to roll steel sheet they only want it to work when holding the forward or revers button what is the best way to do this. its two 415v coil and contactors
thanks
thanks
