C
cbw
Call out today (Sunday PM)
Main switch has melted on a cheap C.U. (---- poor install, John Wayne would have been proud)
I cannot get the bits so have put an MK main switch in, it fits almost perfectly, only problem is the Live and neutral are on opposite sides from the original....... I have relabled the main switch.
IS THIS OK?
no problem as far as i can see.
did you have a loose Neuteral mate..! i had one not long ago and just banged a wylex 100a in a ****ty box also!....!
i now keep 100a Isolators from old CU changes that had MCBs just in case..!
I operate a call out system, I carry so much **** (different types of breakers, lamps, heating valves, etc) in the back of my van I can struggle to get a roll of cable in. But it looks good to the customers when you toll up and are able to sort the problem without having to go back with the bits.
Ian
Nah, it's a double pole switch, as long as you've labelled it up there's nothing wrong with it.
cbw,
rocker,
