K
keithbr13
Hi every one, i have been asked to complete some one elses install, ( i know not a good situation ) and there is an issue with the bore water pump, when the pump operates the led wall lights on the staircase flicker very badly and this continues till the pump cuts out. The pump is a DAB activedriver M/M1 rated at 10 A max fed off a secondary dis board which also feeds the lights. Also on the staircase are led step lights but these are not affected by the pump. Any suggestions please to resolve ?. The dis board is fed with a 10mm T&E from the main Dis board off a 32 A mcb, seems a low rating to me.
