H
hsharp
Hi All
I have been warned about borrowed neutral:
please could anyone tell me where i can find a wiring diagram that details a lighting circuit with a borrowed neutral as i wish to gain a comprehensive understanding to how this would be actually wired & the relationship it would have in relation to the strapper cable.
I have searched the net & this forum and found a No of topics relating to this issue but none describes how it is wired & can only find circuit diagram drawings
any help would be greatly appreciate.
the usual scenario is with a landing light. the neutral is looped from the upstairs cit=rcuit as you'd expect, but instead of the L being taken from upstairs with 3 cores to ther downstairs switch, the L is fed from the downstairs ( generally from the hall switch) with jus 2 strappers going to the upstairs 2 way switch.
there are some on the net. google 2 way switching.
also some good diagrams in previous threads. try a search on the forum.
Here you go
strictly speaking on a 2 way switching scenario as Tel described it would probably be better to call it a borrowed live,as being an upstairs light you would expect the lives to be fed from the upstairs circuit,whereas in that set up it has one from downstair and one from upstairs.
