Discuss Brown plugs on rewires in the UK Electrical Forum area at ElectriciansForums.net
Hello BrianDB9.
That spec. is utter rubbish - just ignore it and fix the hardware as appropriate to your skills and experience. The conditions of every fixing are different and cannot be set down in advance until the masonry has been chased out and the fixings drilled, accounting for concrete, brick, mortar, timber, final loading and any combination of these things. Return the spec. with your tender price on it and a note to this effect.
Regards,
Colin Jenkins.
red plugs, brown plugs, you young 'uns got it easy. we used to have to make the bloody plugs out of the tongues cut from the floorboards we pulled up, drill the holes in engineering brick using a rawltool and hammer, then taper the wood plugs with a rusty knife and hammer them in. happy days.
Luxury, we had to plant t trees, grow em, bite through t trunks to fell them then the apprentice had to cut em up wi his hands. (no namby pamby axes or saws in them days)
Cart em to site on us backs then mek em into plugs. All on a 3 day rewire an all.
Kids these days!
I've even had to whittle dowels and knock them into the walls, between the stonework, just to have something to clip my cables to.
Kids these days!
You were lucky-- we had no electricity...........
You were lucky.We had to bore holes using a woodpecker on a stick and never had a day off even when i had rickets...
Reply to Brown plugs on rewires in the UK Electrical Forum area at ElectriciansForums.net
My wife has a electric heated airer, our dog chewed through the cable and I thought it would be no different from rewiring a plug. It's not. I...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
A friend of mine got a 2nd hand coffee machine (OK, probably 3rd or 4th...) for use in a charity cafe and it has problems. First problem is no...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
