Having closed down my business and gone to employed, I have a garage full of unused stock.....
Looking to get rid of it as one bulk sale, am in North Bristol, however could deliver for a small cost.
Im not going to list everything as I will be all day, but the main bits are:
Luxlite 20W PIR Floodlight
V-tac 50W Floodlight
Enlite 20W PIR Floodlight X2
Zinc Outdoor Black Up/Down Outdoor Light X2
Friedland Spectra Outdoor PIR Sensor X3
Greenbrook 7 day digital timer
Knightbridge Photocell
Floodlight Swivel Bracket X3
Brite Source 600X600 Panel Light X2
Click 1G Outdoor Switch
BG 2G Outdoor Socket
Outdoor FCU
All-led 1w IP65 Marker Light X4
Solo 10w LED Downlight X3
EcoLED 6W LED Downlight X2
Ansell Orbio 360 Downlight X2
Enlite E5 LED Downlight
Aurora 60-400va LED Dimmer module (Green one)
Click GB400 Metal Fire Hood X6
4ft LED Tube X2
5ft LED Tube
162x116x76 Adaptable Box IP67 X2
176x151x95 Adaptable Box IP67
150x150x150 Adaptable Box IP67
Wago Capsule + load of SWA Gland Plates
SWA Submarine Joint Kit, 4X10mm
Wiska 308 Adaptable Box, Black X5
Wiska SWA Gland plates, Misc
Wago XL Box X2
Wago Box X9
Wago Light Box X3
Click 16A Blue light connector X3
Click 100A 2 pole Henley Block X2
Water/Gas Bond Clamp X6
Misc SWA Cable Glands
Misc Cable Clips
Misc Stuffer Glands
Misc Wago Connectors
CPN 32A 3pole Rotary Isolator
Eaton 9KW DOL Starter
Click 80A DB700 Switch Fuse
5 pin 16A Male Plug
5 pin 32A Male Plug
5 pin 32A Male Wall Socket
5 pin 32A Female Wall Socket
Aico EI161 Smoke Alarm X2
Aico EI144RC Heat Alarm
Appleby 1G 25mm Knockout Box X39
Appleby 2G 25mm Knockout Box X23
Appleby 2G 35mm Knockout Box X8
Appleby 2G 47mm Knockout Box X4
Appleby 2G 35mm Drylining Box X9
Click 1G 25mm Patress Box X13
Click 2G 25mm Patress Box X4
Click Mode 1G Socket X16
Click Mode 1G Socket W/ USB
Click Mode 2G Socket X22
Click Mode 1G 2W Light Switch X5
Click Mode 2G 2W Light Switch X13
Click Blank Plates - Various
Click Ceiling Rose X3
BG Ceiling Rose X4
Click Mode FCU X2
BG FCU X3
Click Dual Cooker Outlet Plate
Click Mode Fan Isolator X2
Click 45A Cooker Switch
Click 50A Pull Cord
Click Metal Clad Light Switch
Click Metal Clad 2G Socket
MK 3G Socket X2
Surface Mount Emergency Stop, With 2 NC contact X5
Fire Alarm Break Glass
Optima Compact Gen4 Burglar Alarm Panel
3 phase load guard relay
Various Circuit Breakers - See Pics
CPN 8 way Metal Consumer Unit with 2 RCD's
CPN 4 way Metal Consumer Unit
2" MW Cable Tray - 30M
6" MW Cable Tray - 3M
3" LW Cable Tray - 21M
6" Cable Tray G Hanging Bracket X40
2" Cable Tray Top Hat Brackets X20
38x38 Plastic Trunking - 3M
38x25 SA Plastic Trunking - 9M
25x15 SA Plastic Trunking - 9M
25x16 Plastic Trunking - 6M
16x16 SA Plastic Trunking - 6M
20mm White Plastic Conduit - 18M
20mm Black Plastic Conduit - 36M
Plastic conduit and trunking accessories - Loads, See pics
SWA 3x10mm - ~25M
SWA 3x4mm - ~10M
SWA 3x2.5mm - ~15M
SWA 4x2.5mm - ~10M
HO7 3x10mm - 10M
Singles - See Pic
Galv Trunking 75x75 T Piece X4
Uni-strut Z Spring Nuts ~50
4" flexi extractor ducting ~30M
Open to offers for the lot.
Outdoor FCU
4ft LED Tube X2
5ft LED Tube
Wago XL Box X2
Wago Box X9
Wago Light Box X3
Misc Cable Clips
Misc Stuffer Glands
5 pin 16A Male Plug
5 pin 32A Male Plug
BG Ceiling Rose X4
Click Mode FCU X2
BG FCU X3
Click 50A Pull Cord
MK 3G Socket X2
SWA 3x10mm - ~25M
SWA 3x4mm - ~10M
SWA 3x2.5mm - ~15M
SWA 4x2.5mm - ~10M
HO7 3x10mm - 10M
Singles - See Pic
