I went to quote for some remedials on Friday, it seems the person who did the EICR thought that connector blocks in a DB are a C1 needing to be replaced with insulated crimps!
Where do people get these ridiculous ideas from?
Crimps in a cu do look a neater job and are easier to disguise however,
Its things like this is the reason i hate this industry sometimes, ive had more than a few occansions where ive given customers advice or installed some work for them, then another 'spark' has come along and rubbished it saying its 'illegal' and generally making us both look like muppets, no wonder the public find it hard to trust tradesmen
Last time was a rewire i was pricing for, the customer was suffering from extreme green goo leaking from all the sockets and switches even after she had it cleaned it returned after a few months, i said the only real cure was to rewire the old cabling, but was a fairly painless job as it was all sleeved with conduit in the walls and floorboards were exposed etc
Some nob head come in after me and tells her im talking rubbish, its 'illegal' to use the old steel conduit in the walls and needs to be ripped out and replaced with pvc capping, and thats where the goo is coming from anyway(and its actually a form of rust)!
As for extending cables, increasing the resistance of your cable readings....if thats the case, your joint is crap and you havent done your job properly, what the hell else are connector blocks for
(disclaimer. as long as they are adequatly rated and enclosed, not exposed and/or wrapped in tape, and are accessible for maintenance)
If thats what a college lecturer is teaching all the students what chance do we all have!
I think the average person whos tries to be an electrician simply hasn't got the intelligence level, not that you need to be a total genius(but it helps). :)
carlos, i think your tutor should have said that a joint is a possible point of failure if done badly. a poorly terminated cable ccan also be a failure,
I believe you are correct telectrix.
We all (students) hold both our tutors with great respect and, I know even though I lack the field experience, there hasn't been a time when they couldn't answer me a question.
Sadly we lost one tutor as he's had enough of the paperwork that teaching has become and he's now back on the field.
If experience is anything to show, well, suffice to say that from all 4 business he contacted, they all offered him a job (he's worked for them in the past), so surely he knows his electrics.
Many thanks for your input.
Regards,
Albert
Some nob head come in after me and tells her im talking rubbish, its 'illegal' to use the old steel conduit in the walls and needs to be ripped out and replaced with pvc capping, and thats where the goo is coming from anyway!!!
I do agree with you to some extent. As for example, the course started with 29 students and we are now only 8. Maths was the main issue for the most.
And I do feel for the most honest sparkys out there who will try their best to do a decent job, maintaining a balance between what needs to be done vs keeping to the regs vs quote £. It is depressing not to get a job because some knuckle head who calls himself electrician, has under quoted us thus getting the job. Off course, the customer will likely (unless the house burns to the ground) never know that regulations haven't been either followed and/or meet. But sadly, in the times we are living, the customers are more than likely overlook the quality of a job well done in favor of the cheapest quote. Regrettably, I know.
Many thanks for the input.
Regards,
Albert (My second name if anybody wonders.)
Hi Tony.
Just to put your mind to rest, I did not paid extra for the course.
In fact, I am at the local government college and have had to fork £3.7K for my level 3 education.
My comment is only due to the various times tutors have mentioned that a joint cable, either by terminal block or grimp or whatever the method, will always be a week point and can add resistance to the circuit, sometimes enough to fail the basic R1+R2 test.
I too, did always wondered, hence my question here on the forum, to the likes of yourself and all the great experienced electricians that are part of this community, as I always thought that rewiring a whole house because cables are too small sounds a bit harse and would also add to the final quote.
Still, many thanks to you all, for all the comments and time taken to give your thoughts/experience to the likes of us, like myself, who are less elusive.
Many thanks.
Regards,
Albert
If crimped by 'Tel's' worn out teeth then I'd agree! :)
One of the important things is getting the correct crimping tool, without that you’re snookered.
The lads will have up to date information on what’s available now, the set I have is 30 years old so no point me digging them out to look for the make. That said they’ve hardly seen much work so still as good as the day they were issued to me.
For MV work I’d still use weakbacks and solder.
I can joint cables up to 33KV and they will carry full load. Your tutor doesn't know what he's talking about.
Ahhh ... but T, you have a lifetime of training and hard won experience behind you. Furthermore, I d wager that the quality of your training far exceeded that which many 'training' companies provide today!
That’s an understatement kid.
Training has gone to the dogs I’m sorry to say.
... I think I know that you are in retirement ... I should have been drawing my military pension by now but redundancy got in the way! I am old enough to be going through a mid-life crisis ... less of the young goat ... please?
Carlos Arruda,
GB.Kayak,
