It's not a power circuit, it's lighting. And the photocell will work happily with leds.
it's a lighting circuit....1mm
Should have read the post properly, and looked under the Lighting circuits column instead on the Power Circuits. 1.0mm it is.
I assumed (yeh, I know...) that, as he had mentioned 0.75mm2 he was talking about doing it in flex. Something like H05 perhaps?
In which case isn't it "non sheathed and sheathed flexible cables = 0.75mm2" ?
