I need a cable for 10kW/44Amps Shower. 10M run
TLC Catalogue for T&E 6242Y recommends 10mm upto 53 Amps. Doncaster Cables online calc reckons 4mm.
Draka online calc agrees with TLC. Common sense also says 10mm.
What have I got wrong for Doncaster to suggest 4mm?
Michael
Why not buy a cable calc programme there's plenty of software out there but even then you still need to do a manual check with the regs book now and then to check the cable selections
No offence intended, but the first thing any electrician will tell you when asking about a 10kw shower is that you need at least 10mm. Are you actually an electrician mate, as this is a notifiable job?
I remember looking at that Doncaster tool a while ago and it seemed to be blatantly wrong. I was sad cos I really like Doncaster cable, I find it the easiest to work with, although it can be overly powdery inside. Not that that has anything to do with their kak cable calculator of course. Just saying. :)
Kent
Cable Size
Michaelwgroves,
Michaelwgroves,
