Discuss Cable type for 24vdc circuit in the UK Electrical Forum area at ElectriciansForums.net
Hi All
I have been asked to install a small BMS system in my local community centre for whom I do all their normal electrical work.
All the radiators are being fitted with 24 vdc actuators, each drawing 30mA when operating. There will be a maximum of 2 actuators on each cable run.
The BMS manufacturer has recommended using Firetec Standard multi core LSZH 1.5mm claiming that's what "the regulations" state.
Seems total overkill to me (notwithstanding difficult to work with) but I am not familiar with the cable regulations for this type of circuit.
Any advice or pointers gratefully received.
Most BMS installations use this type of cable, it's screened and rated to 240v so it can be run in the same containment as power within reason. Without sounding like an arse I've never struggled to terminate it. Get a sharp knife and your away.
Not true, I do a lot of work around Trend systems and all their low power stuff uses 2 twisted pair belden type at 22awg
there's nowt in BS7671, except that cable should be suitable for it's use and it's environment. belden cable would be my choice unless you had very long runs and volt drop was a problem.
Reply to Cable type for 24vdc circuit in the UK Electrical Forum area at ElectriciansForums.net
H
I'd be very grateful if someone can help with this..... I've added a diagram to help explain. This is single cabling not a ring (I'm in France)...
6K
T
I currently have an integral garage fed by a radial circuit protected by a 32A MCB and wired with 4mm T&E cable. This feeds just two power points...
10K
Good Afternoon, Would appreciate a few thoughts, and before anyone shouts this is NOT my design or installation a fault find and repair job...
T
Hi, First let me just say that I am not an electrician although in the past I've done the usual garage and shed wiring without having any...
8K
Thai Amateur
T
Situtation is a new, small garage (16 sq m) fed from the house via a 16A mcb and 30mA main RCD. I am doing my own installation under a Building...
11K
Adam W
A
