Discuss Calculate power consumption in the Australia area at ElectriciansForums.net
A
ashokkumar8226
Hi,
i have projector voltage is 110-240v and max power 300w what will be the consumption of power in one hour and what is the load it requires.
Thanks & regards
Mark, could you please explain where the 1.3 amp comes from?
He's basically simplified calculation by using the figure of 1000w and then used the % of 300w from 1000w thus being 30%. 30% of 4.2amp is 1.3amp.
Mark
Hey Dan.
the 1.3 A is the current used by the 300W load in the original example - 300W/230V - 1.3A, power triangle.
Then divide 1 kwh by the 300W load to get a sum of 3.33p per hour roghly rounded up to 3.5p.
Hope this helps.
Ne bother.
It is amazing though how much we were taught and how much we actually use in day to day life. Forgetting it is a dam sight easier than learning it ever was and trying to remember it again is even worse.
Cheers.
Reply to Calculate power consumption in the Australia area at ElectriciansForums.net
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
Hi everyone, I have a basic knowledge of electric but would like advice before I attempt, I have a electrical item that is powered by Voltage...
Hi, I have purchased a piece of equipment from China and we are required to finish the final wiring. They have supplied a length of 3 core 6m...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
